So I thought id have a go at buying a cheap (£8 delivered) ebay vagcom lead with one of those mini discs.
I have heard a mixture of good and bad but thought it was worth a punt
It took a few minutes to install the program but then the fun started, my obd ports are dead and whenever I want to use them I have to hard wire a live feed from one of the fuses.
I had to search high and low on the net about how to get the car to hook up to the laptop, and it was to do with the "comm ports" so had to slightly reprogram the system but eventually got there.
It connected soon after, I saw the title come up of my current chips
Finally managed to search for fault codes and it said 305 were stored
I began to work my way down but then.....the program stalled and I haven't been able to get back on since.
I'm fairly sure I loaded the program twice in error, could this be the cause?
Thanks chaps
Thanks chaps
