Check to ensure field coils are getting 12v. (little wire).
Test would be to use a short wire to energize the field coils by shorting to main terminal while car is idling. The alternation will start charging, if this is the problem.
Tightened, it was a bit loose but nice and secure now. Light still came on a few times after I tightened the belt but has been OK for last few runs, fingers crossedl. I sprayed a bit of contact cleaner about when I checked the connections maybe that has done the trick.
