Well it seems electrical gremlins are at work... for some odd reason when I have the column light switch in sidelight mode, the LH and RH tail lights work great, however when I put them in dipped or main beam the LH tail lights go off!
Any ideas? The lights were working perfectly, and I am not getting any voltage to the grey/black wire which I believe to be the tail lights, at least when in dipped mode.
I've seen on a schematic something to do with a lighting control unit? Where is this?
Cheers,
Pete.
Cheers,
Pete.
