Buy a pin and stick all the old #8 wires and the yellow one to it.
If I had ellipsoids I would put a switch somewhere where I could select if I wish to use mains with or without lows. Bright spot near the car just makes seeing worse even if you think you see more...
Thanks for that,
Still slightly confused as the leveling motors dont function on full beam which would lead me to believe that there is no power to #8 on full beam.
Test this evening and let you know, Like the idea of switching the mod.
