I have an AAN converted B3 80q.
My ECU isn't getting a road speed signal and I'm reliably informed this is ECU pin 50 and needs a reading from my clocks.
Can anyone tell me if standard 2.0 8v clock wiring has this wire, and what colour wire it is on the ECU end and the clock end (I would assume the same colour but nothing is ever that easy!).
Also assuming the AAN loom has the wire I need, as the 3B loom doesn't apparently...
Thanks!
Thanks!
