Audi RS2 no starter
  • Billman
    • 4129
    Off topic continues... new clutch pedal related thread started in the transmission section.
    Go Holset or Go RS4
    • Condor
      • Jul 2004
      • 424
      None starter
      Interesting as my S2 has a similar problem, occasionally it won't engage the starter, the dash lights come on as normal when the ignition key is turned but the starter doesn't engage, it's just dead, I've checked the starter end, I've "wiggled" the relays in the fusebox when this has happen and on occasion this appears to have done something to temporarily fixed the problem, it has happened with the engine cold & hot, I'd really like to find and fix this.
      :wave: :thumbs:
      • OrlandO
        • May 2013
        • 75
        • Country: Latvia
        My mate had similar problem with his VW - turned out to be the ground cable, it had some corrosion on it. He took it off, cleaned both ends, put it all back and the problem was solved.
        • Condor
          • Jul 2004
          • 424
          Thanks for the tip, I'll have to check it out...Condor
          :wave: :thumbs:
