Help please: basic wiring
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    Try refitting the gauge to see if that completes the circuit again. then you can work from there.
    pull all fuses and look over them.
    • Jack4688
      • May 2010
      • 1004
      Originally posted by Monkeymagic
      Did you cut through all wires at the same ttime? I reckon you've blown fuse 4 at least. Are reg plate lights working?
      Pretty much yeah I'll check after tea
      • Jack4688
        • May 2010
        • 1004
        Bit of an oversight by me - The dial backlighting is fine, as is the number plate light. I made the assumption yesterday morning when in light fog I switched on the sidelights and noticed no clock.
        What I am missing is: Radio (who cares when you've got 5 cylinders anyway); Clock; interior light and; instrument cluster display. But having the MPG visible isn't good for the mental health of an S2 owner anyway.
        So with the stress of buying a house starting to get to me right now I'm marking this one down as ultra-low priority I can just tuck the wires away for now until I need to do something about it.
        EDIT: And thanks for all your help fellas
        • Monkeymagic
          • Mar 2012
          • 3419
          Then you have blown fuse 14. You will have a separate fuse in the back of head unit I'd check that too.
          • Monkeymagic
            • Mar 2012
            • 3419
            I. Mean number 4 fuse. I'd imagine one of the wires is tapped into the lighting and in cutting all 3 you blown fuse 4
            • Jack4688
              • May 2010
              • 1004
              Just a blown fuse - I'm going to miss being oblivious to how poor my MPG is
              But on the plus side I can put the radio back on and be oblivious to any knocks and/or groans instead
