My s2 just caught on fire!!!
  • freakytate
    • Jun 2014
    • 206
    i was cleaning the a pillar interior panels, i moved the pass sunvisor and saw what looked like a puff of dust. carried on, next thing plumes of smoke coming from roof and dash area! I sh#t myself....lukily had spanner to undo battery.
    I have traced it to the bosch alarm system with the funny sensor unit screwed to the roof control panel. i was going to cut it off the other day. i have stripped some of dash and traced loom to the plugs into the bosch unit......
    all wires up to roof unit have melted, the melted wires seem to be spliced / soldered onto existing wires.
    a pillar....
    i need to trace all wiring and hope it hasnt fried ecu or something similar. i need to by pass this alarm now, anybody have any advice please? never done before, i am a spark and guessing its just a relay contact that cuts power to certain items in car such as ecu possibly and or starter circuit..
    i am hoping this wont be as much trouble as it looks.
    aaarrrghhhh
  • K Simmonds
    • Dec 2007
    • 7633
    Right, I'm having a look under my RS2's drivers dash panel this weekend, I knew it was sensible carrying a fire extinguisher.
    I expect you'll be fine if you got the battery disconnected quickly, just remove all the obvious after-market stuff and join the factory wires back together, good luck!!!
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • Michael S2
      • Dec 2011
      • 1378
      Where was the black box attached to?
      I always carry a fire extinguisher as well. Hope you get it sorted soon.
      1995 Audi S2 Avant
      • freakytate
        • Jun 2014
        • 206
        It has melted a good part of the alarm loom. Hope no further back.
        Black box was connected to yellow led on centre switch panel, a part of loom going towards ignition module / switch or in that direction past radio by clocks etc. The other part goes down under by passenger carpet possibly forwards then towards the main loom or ecu. Will know more in morning. Im nights so have time in day to strip it a bit. Car has old school foxguard immibiliser too.
        Alarm has never gone off. Didnt know it had one or worked but its going off now if i plug all back in and connect battery. No power to starter. Ignition is coming on though
        • freakytate
          • Jun 2014
          • 206
          Black box was located up by bulkhead in ecu area ish
          • freakytate
            • Jun 2014
            • 206
            anyone know if this is standard equipment or an aftermarket unit?
              No Audi PN numbers = probably aftermarket. Found several references to Merceded Benz vehicles circa 1992.
              Alarm relay control unit alarm Bosch 0335411052
              http://www.ebay.de/itm/Mercedes-Benz...-/160873937763
              • freakytate
                • Jun 2014
                • 206
                I can find nowt on it as far as instructions or wiring diagrams. Il just try and remove it. It has markings for each terminal but i cant decipher what they mean.
                disheartened to say the least, never mind could have been worse
                • K Simmonds
                  • Dec 2007
                  • 7633
                  It could have been game over if you weren't lucky enough to be with the car when it happened and had the good sense to disconnect the battery promptly.
                  De-alarming cars isn't hard, it's just time consuming and a little fiddly if you want to do a tidy job. I can get past most after-market systems and have the engine running in under ten min's but putting it all back tidily takes a lot more time.
                  No I'm not a car thief.
                  1994 MTM RS2.
                  2000 B5 TQS.
                  • freakytate
                    • Jun 2014
                    • 206
                    i hve found the culprit. someone has screwed sun visor base through the wires to the interior sensor. i have no diagram now so am looking as to what circuit it is interrupting. its a bosch bloctronic. want the car running today regardless of interior mess. what do they normally interupt? starter circuit, fuel or power to ingnition coils etc?
                    cheers
                    • freakytate
                      • Jun 2014
                      • 206
                      any ideas if i can short out any pins on module to frig into healthy state
                      connector block terminals are as follows....
                      any help greatly appreciated. car has foxguard immobiliser too with old school little stick thing you push in until led stop flashing then it will turn over.
                        Immobs normally break 2 circuits.
                        If the car won't crank the immob is cutting the starter.
                        Often they cut fuel pump, sometimes ignition as well. To bypass the immob you need to find where the aftermarket crap cuts the OEM harness and solder it back together.
                        With Thatcham approved installs you can normally identify these connections by a ragged mess of peeling insulation tape roughly covering a greasy ball of bird **** solder the size of your thumb
                        • snaak
                          • 153
                          '95 RS2
                          • K Simmonds
                            • Dec 2007
                            • 7633
                            Yep, that pretty much sum's it up.
                            1994 MTM RS2.
                            2000 B5 TQS.
                            • freakytate
                              • Jun 2014
                              • 206
                              ha, sorted. got the car running by shorting out starter relay contacts off alarm. just disconnecting one by one now to make sure everything still works as it should.
                              i used this as reference
                              http://www.500eboard.com/forums/show...hp?t=3258&
                              Spara pengar med en rabattkod. Klicka in. nu och få de senaste rabatterna och erbjudandena du hittar hos Kickback Rabattkoder.
                              cheers guys, just need to trace alarm loom properly all way back to where they tapped in and remove and make nice job of it
                              car is running and immobiliser still working
