7a ecu only 98 fuel?
  • ACQ
    • Jun 2008
    • 141
    • Country: Lithuania
    I was breaking audi 90q with 7a engine for spares, which had really more power than other 7a engines I have drived.
    It has such ecu (see photo) Is it original stick or not? because never see it on 7a ecu before. May it has a chip or something...
    I would say that there is a possibilty that that 7A ECU is modified because of a) the 98 RON sticker and b) the hand written red pen note on the box, indicating, to me, that the ECU was sent away to some one who was modding various ECUs and needed to make sure that one went back to its 7A owner.
    BTW dropbox sucks for bringing photos to this forum.
    • _ShurikeN
      • Mar 2010
      • 733
      • Country: Russian Federation
      There is a guy in my city with 7A swapped in Coupe t85. He has 2 ECUs: stock and chipped. The car acts different with them.
      • ACQ
        • Jun 2008
        • 141
        removed a holder and found https://www.dropbox.com/sc/2eic0aj2g...W-W06uBLI2Jxoa
        • Bowie69
          • Nov 2013
          • 2680
          Oh nice!
          but yes, 97+ RON is still recommended for the 7A anyways. Suspect there is more timing in the ABT setup requiring the higher RON.
          • Nj
            • Jan 2007
            • 3420
            • Home: Scotland Current: Finland
            Really? Is it worth chipping a standard 7A then, even though it's naturally aspirated?
            1990 CQ20v
            • mcandmar
              • Apr 2004
              • 5118
              Not really. I picked up a chip for mine many years ago and the only real difference was a little more torque between 2-4000rpms, it basically ironed out that flat spot ~3k.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • Bowie69
                • Nov 2013
                • 2680
                Yup, exactly, the timing increase was likely in the low range, and reports only gave a moderate torque increase as opposed to all out power. Around 7BHP IIRC was the quoted figure, btu better drivabilty. You wouldn't notice it after a month I would say.
                You are better off working on the intake side of things, throttle body, airbox, MAF etc, which are all restrictive/flow poorly. That and if you have the later cast exhaust manifold, swap it for the earlier bunch of bananas, this was 7-10BHP also IIRC, but more at top end.
                • Nj
                  • Jan 2007
                  • 3420
                  thanks gents. kind of confirms what I thought about chipping/remapping anything without a turbo. When I finally get my car home no doubt I'll spend a lot of time wishing it was my S2 and then wondering whether I should just enjoy it or do something silly like keep an eye out for an 034 kit
                  1990 CQ20v
                  • varia
                    • 821
                    • Current: United States
                    I had TAP1 chip (15 HP according to their site) in my 91 CQ 20V 7A, with big MAF (? HP) , and bosch injectors (5HP) and tubular header (5-6HP)
                    The car was night and day compare to a stock one.
                    • John.
                      • 2615
                      I have different injectors and chip......switchable back to standard.
                      Difference noticeable when driving, haven't had it on a rolling road.
                      I'd be interested to hear more of what folk have done regards the air flow sensor and throttle body.
                      • ACQ
                        • Jun 2008
                        • 141
                        In this car where was this ecu installed, also was ported intake maifold
                        • Nj
                          • Jan 2007
                          • 3420
                          john, what chip did you get and where from? and what injectors did you get?
                          looks like it might be worth a bit of tinkering to squeeze a little more power (famous last words)
                          1990 CQ20v
                          • John.
                            • 2615
                            Sorry I can't say exactly what spec they are but have PM'd you to explain!
