Ordered a RightClick KE851HC radio frequency remote for my UrS4 avant with central locking but no remote or immobilizer. http://www.rclick.co.uk/product_info...oducts_id=1152 Ordered May 6th, arrived today. Now I have some questions:
1. Where is the best mounting location in a C4? I was going to go for under the rear seat because of the proximity to the OE Audi Central Locking Control Module and the battery for power.
2. The aerial wire coming out of the RightClick black box is only about 8 inches long. I was going to run it up the back of the avant rear seat but would have to extend the wire to do that. If it is just a stranded wire, no problem but if it is coax or something, that would be difficult.
3. If you have a RightClick system, did you install the blue ARMED LED?
4. Did you bother with the immobilizer function?
Hopefully that will be it for questions.
The wires you want to trigger are from the drivers door, easiest way to find these, is err... at the drivers door
