Just need to check / need confirmation.
From the fuel relay to the actual pump the loom is a straight run (I.e no other fuses / relays / connectors) in the way. need to trace a fault. May be useful info before i start ripping things too bits.
Had a look at the wiring diagrams and it seems a complete run/wire.
I know there's a hundred posts about the FPR and read all of them. Now im convinced its a post relay issue.
Problem: relay works, has power, activates on crank. No juice coming to pump.
Crank and cam sensors new and confident about these.
Pump did work whilst bridging the relay, but now does not. But still works and starts fine when directly powered.
many thanks.
many thanks.
