S2 Coupe Electric Windows Not Working & Abs Light On???
  • audimaniac
    • Feb 2007
    • 152
    Hi Guys
    Had the S2 Stood now for three weeks ish and a strange thing has happened, i had to charge the car as when stood for a while, my battery go's flat but used to that particular problem now, anyways, when the battery was re-charged, i connected back up and never thought anything else about it until today, went out for a run and to my surprise, i had the ABS Light lit up on my dash and also, my electric windows were Not working either??? Checked fuses under Bonnet and all ok but Not checked under Dash as yet, but im struggling to point the problem to relays at the moment?? I don't want to spend hours of looking, so have any of you guys had a similar problem???
    Thankyou in advance people.
    Electric window relay is the double width one under the dash, give it a wiggle and see if your windows come to life. If so then prise off the top and resolder the broken connection. ABS could just be a dirty sensor or toothed ring.
