12v permanent
  • pcfnet
    • Jul 2011
    • 117
    • Country: Hong Kong
    12v permanent
    Hi I know this sounds rather simple question and I did try to look for answer in forum - but I failed...
    Can someone advice where the easier /most sensible 12v permanent feed I can get inside the car under the dash.
    I need this for my black box with auto shut down features...
    RS2 >> Ferrari: Performance/look ratio
  • John.
    • 2615
    Radio wiring would be easy to access?
    How many amps will your "black box" be drawing?
      Should be a decently thick red wire going into the back of the cigarette lighter that you could tap into. The cigarette lighter is on permanent "30" bus wiring, protected by a 15 Amp fuse in position S4.
      • pcfnet
        • Jul 2011
        • 117
        thanks guys.
        the blackbox rated 10W max and avg 6.6W. so I would say 1A is more than enough
