Ignition Module Switch Audi 7A 20V - where is placed?
  • mihai_antony
    • Nov 2011
    • 150
    • Country: Romania
    Hello
    I have a b4 with a 7A motor swap and i have big problems with starting the engine, a lot of no start, or hard starting and misfiring.
    I've changed almost all the stuff, OE or Bosch
    - new dizzy, correct alignment
    - new sensors (the two from flywheel and the coolant sensor from the back)
    - new coil
    - ignition contact
    - ECU
    - pin from the FW it is ok
    - battery it is ok
    Knock sensors - didn't changed but i don't belived that they influence the start of motor.
    All the wiring, from ECU to sensors, to coil, to MAF, to ground - everything is ok but no spark, or hard and random starting. When i have spark and finally the motor start the idle is ok, engine is running ok. If i stop and i want to start again - i have no spark..it's a crazy
    The problem is that the spark from the coil is random, i have the power on coil but no start or spark. I've seen one thing: when i turn on the contact the voltage is low (9.4-9,5V)
    I read a lot on the forums and the problems could be from the ignition module switch (amplifier), but the problems is that i didn't fiind this module in my car. Maybe previous owner miss to put when the swap was made?
    Please help with a picture in order to know where should be placed,
    Thank you very much!
    Mihai
  • mihai_antony
    • Nov 2011
    • 150
    • Country: Romania
    and the code is 191905351B
    • Mikes2
      • 1704
      20v cars don't have that module
      Mike
      http://www.s2-audi.co.uk
      • mihai_antony
        • Nov 2011
        • 150
        • Country: Romania
        Thank you Mikes2!
        i will go ahead with further investigations, but i'm really out of options. Check again all the fuses and relais
        • Mikes2
          • 1704
          One thing to check is the wiring inside the boot of the connector at the distributor. If that is damaged, you will not get spark
          Mike
          • SA BOY
            • Feb 2011
            • 310
            • Home: South Africa Current: United Kingdom
            Are you sure it is not a fuel problem?
            • mihai_antony
              • Nov 2011
              • 150
              • Country: Romania
              Hello
              Can be a fuel problem if i have no spark from the coil?
              The fuel pump is working, fuel pressure ok
                7A Ignition Coil with Power Output Stage PN
                Originally posted by Mikes2
                20v cars don't have that (191905351B) module
                Agree. 7A's had a 8A0905105 coil with attached power output stage (POS) module. Yours might be dead.
                http://www.ebay.com/itm/BERU-Germany...-/111439430542
                • Bowie69
                  • Nov 2013
                  • 2676
                  That's the one, I have one on the shelf for when mine dies!
