Hello I have had this problem occur in the past and thought I had cured it alas NOT when I operate either left or right hand flasher the hazards operate, in the past I have changed the relay,the hazard switch everything worked then it's back to normal hazards on when indicating right or left ,I renewed both rear light units (twice) , everything works fine ,after a short while the fault comes back again , I finally changed the stalk with a brand new one , yippee it worked for about 2 weeks now it's back to normal hazards on all the time when indicating left or right ,any of you electrical guru,s HELP,point me in the right direction please.Derek
