Autocheck - distance feed?
  • LHD_Kid
    • May 2006
    • 3697
    I'm trying to find why my autocheck doesn't quite work.
    Where does it get the distance information from?
    The cluster is receiving speed information (speedo works fine and average speed is showing as calculated correctly)
    Instantaneous mpg and average mpg do not work
    G22 Vehicle Speed Sensor (VSS) 012409191D Info - What it is and where the signal goes
    Read this:
    G22 Vehicle Speed Sensor (VSS) 012409191D Info - What it is and where the signal goes:
    • Mikes2
      • 1704
      the fuel consumption signal comes from your ecu.
      It uses that to work out your range
      Mike
      http://www.s2-audi.co.uk
      • ManiacuV6
        • Dec 2009
        • 458
        • Country: Romania
        Mostly fuel consumption signal is a yellow wire.
        Audi S4 2.2T 5 spd 1992 for parts
        AUDI A4 1.9TDI daily use
        Audi 80 Quattro 2.0 16V (ACE) aka Competition
        • LHD_Kid
          • May 2006
          • 3697
          Thanks for this so far...
          Dave, I've read through the post - but seems to be more around the speed signal (with which I don't have an issue), but did follow the active links to the pin outs...
          I can't see from the list which wire feeds the cluster from the ECU - I'll keep reading anyway...
          If I can identify which wire, I might try running a temporary new wire from A to B for test... then I can trace the wire as needed...
          Think I might struggle to find it though...!
            Have a look at this and particularly the info regarding pin T55/31 and T55/50. 31 = fuel consumption and 50 = vehicle speed (and distance base on math):
            Example 20VT ECU pin-out:
            31 is connected to T10a/5 of the J128 board computer in an AAN.
            • LHD_Kid
              • May 2006
              • 3697
              Thanks Dave..
              Ok, some time spent with AAN schematic and 3B pin outs...
              Its blue/black wire from pin T 32/55 for the fuel consumption on the 3B....
              Mine is converted to AAN, so should be T 31/55 but via a slightly different route to the cluster...
              A little more time available at the weekend I hope
              For reference, same issue before/ after ECU conversion and the same with 2 different clusters...
              • gmac78
                • Oct 2009
                • 928
                • Home: Scotland
                Good luck with this one, i've just not had time to trace all the wiring for this fault. My trip computer has started working a lot more on a daily basis now, so i would say there has to be a dodgy connection somewhere. It's still annoying though so be good to get to the bottom of it.
                  Not sure if you followed the "Connector Stn 2" link in the T55/31 info listing in my AAN ECU pin-out post or not:
                  "31/55- Fuel consumption signal for trip computer - BL/BK - Note: only used in N.America on 92 spec cars (But still available at Connector Stn.2 )
                  32/55-Output to Trip Computer Boost Pressure Gauge - Y/BL - Note: only used in N.America on 92 spec cars (But still available at Connector Stn.2 )"
                  Here is that link: http://forums.quattroworld.com/s4s6/msgs/209044.phtml
                  In the Connector Stn 2 info, you will find this:
                  "Recently, Audi_F4i flagged a couple of issues related to corrosion in the Connector Stn. 2 connectors:
                  "(My)speedometer has been acting up for the past year or so. Installed a new G22 Vehicle Speed Sensor twice and even bought another Instrument Cluster off audifans to no avail. Decided to do a continuity test with a multimeter and was not getting continuity between the top and bottom of the T6c connector, speedometer 1/6 red/brown wire (red 6 pin connector located in the right hand kick panel). Pulled them apart:"
                  • Tridac
                    • Mar 2012
                    • 88
                    Distance Feed
                    If the speed is working ok, then the sender must be ok. The pin connectors on the panel can corrode and cause intermittent faults. Strip down the cluster, take all the screws out and take all the various boards off. Clean all the pins with a fibreglass pen, lightly spray all the pins with silicon spray (not wd 40, must be silicon) reassemble and see if that fixes the problem. Silicon spray is good for all the other connectors on the car as as well, especially on older vehicles where the rubber seal around the connector fails Damp gets in over the years and the voltage drop across the connector causes dissimilar metal / electrolytic corrosion...
                    Chris
                    • LHD_Kid
                      • May 2006
                      • 3697
                      Been raining all weekend - not had a chance to investigate further...
                      Both clusters I have tried havd been fully cleaned and checked and work fine in another car. Must be wiring issue between ECU and cluster - it didn't work with the 3B ECU prior to conversion to ABY so need to trace the wire.
                      Can anyone confirm how the wire connects at the cluster on a 3B? Which connector?
                      I tried the wiring diagrams at S2central but don't seem to open
                      Dave, I had a good read of the links - excellent info, but the wiring (route and plugs) seem to be different on the Euro 3B.
                      Once there is some better weather I can take it outside and open the doors without getting soaked...
                      Thanks for the help so far...
                      • Mikes2
                        • 1704
                        It's in the small black connector for the computer screen
                        Mike
                        • LHD_Kid
                          • May 2006
                          • 3697
                          So, via this plug right,
                          Does anyone know which pin or wire colour it is at the cluster end?
                          It appears the wire changes colour from blue with black stripe to another colour, possibly at a single pin yellow plug....
                          • LHD_Kid
                            • May 2006
                            • 3697
                            Surely the autocheck is fed by the 26 pin white plug?
                              Can anyone confirm how the wire connects at the cluster on a 3B? Which connector? I tried the wiring diagrams at S2central but don't seem to open
                              I tried to poke around the S2Central labyrinth but didn't have much luck. I tried downloading this but nothing happened:
