HID fitment - where are you locating your ballast ?
  • gavs20v
    • Sep 2004
    • 3057
    Evening ,
    Does anyone have any pics of how they've Discretely mounted their HID ballasts ? Last time I fitted a set I just left the ballast lose but oils like something a little more substantial / pretty
    Thanks in advance
    Gav
    S2 Cabriolet.........
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    Originally posted by gavs20v
    Evening ,
    Thanks in advance
    Gav
    • piotr
      • Jul 2012
      • 1470
      You can just about to see them,then are glued on to the plastic panels behind headlamps.
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        Mine are sat under each headlight on the housing of the lamps
        Mine are slim type balaster
          I just took mine out.. One was floating under the light, the other was held in place by the fog light
            TECHMAX LED Headlight Bulbs All-in-One Conversion Kit - H1 -7,200Lm 60W 6000K Cool White CREE - 3 Year Warranty
            Smaller than a matchbox 'ballast' that can fit inside the headlight assembly.
            • gavs20v
              • Sep 2004
              • 3057
              https://www.amazon.co.uk/TECHMAX-Hea.../dp/B01I4J78J4
              They look good. Will try them for the dogs. I already have the hids4u kit for the headlights. Ballasts are nice and slim
              Just looking for ideas
              • s2driveruk
                • 12696
                I have one under the airbox and one on a home made bracket next to the ps reservoir.
                Those linked to above...do they actually fit in an s2 projector headlamp...they look massive?
                1992 3b S2 Coupe
                  I fitted a new kit to the avant today, one ballast on the plastic panel in front of the PS reservoir
                  One on the plastic panel below the air box intake.
                  2 self tappers each
                  • SteveH
                    • 4460
                    Are the LED's getting any better? I tried them 12 months ago and the light output was pants!
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • CoupeWannabeS2
                      • 403
                      https://www.amazon.co.uk/s/?ie=UTF8&...l_6sdrczmame_b
                      Can I just check, have you fitted this kit to S2 projector headlights? If so is it straight forward, and easy to do? Do the ballast's fit in the headlight assembly?
                      Many thanks.
                        Many thanks.
                        The bulb has a heatsink with a fan.
                        So I would think you have to leave the cover off the back of the headlight, or cut a hole in the cover?
                        Macspring, how did you fit these?
                        • AndyP
                          • 6049
                          I use those double sided sticky pads for mounting number plates to hold mine down, they work a treat
                          http://www.ebay.co.uk/itm/Registrati...UAAOSwWTRWxJKc
                          • s2driveruk
                            • 12696
                            That was what i figured you would need to do...not ideal really. Will look for a solution which enables me to use the covers as i am now with the current old hids
                            1992 3b S2 Coupe
