Engine earth points only on IM?
  • Jonas_R
    • 3781
    • Country: Denmark
    So the guy who owned the car before me had put a big earth strap from the intake manifold to the strut bar.
    Car still have the original ground wires on the Intake manifold.
    But are there any other earth points on engine? How about on chassis in engine compartment?
    I would like to remove the strap, but what should I check to see that everything is ok?
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • sjw185
    • 1175
    Jonas,
    There is a earth cable that goes from the chassis leg to the block above the oil cooler.
    Passes through the red ringed grommets with the main 12v feed to starter motor.
    • andy10v
      • 5996
      Off the top of my head the big one on a 3B was bellhousing, ABY turbo side chassis leg-block, should be 2 small earth connection points on the intake manifold.
      Sold ABY-stock
      • Jonas_R
        • 3781
        • Country: Denmark
        Ok so one big earth strap at turbo side and the ones on IM, that should be it?
        Can it be bought as a spare part?
        • Jonas_R
          • 3781
          • Country: Denmark
          Found this on a german site, seems to be right for aby
          • SteveH
            • 4460
            Same on the 3B too.
            91 Modded 3B
            14 A6 Avant Black Edition
            • Jonas_R
              • 3781
              • Country: Denmark
              Ok do you know what size it is?
              • Jonas_R
                • 3781
                • Country: Denmark
                I can get a 600mm long that is 16mm2 or I can get a 350mm long that is 35mm2
                Is 350mm long enough?
                  Same idea for an AAN:
                  Photo courtesy of Preston_Brown
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    Thx do you happen to know the thickness of the cable?
                    • sjw185
                      • 1175
                      600mm long 16mm2 is more like it.
                      Think 350mm would be a bit tight.
                      You can always loose a bit of slack at the chassis leg.
                      • sjw185
                        • 1175
                        Found picture of one fitted to 3b, Fitted at engine mount on chassis then to tapped hole above oil pressure switch.
