Bit of a cry for help this,
or is it a challenge for you to get your teeth into? :mischeif:
My VR6
has p!ssed coolant into the 42-pin Engine loom to Non-engine loom connector, resulting in corroded pins.
Now I'm more than happy to strip the connector down and clean / replace pins as neccesary, but where can I get hold of nice new versions of the little captive connectors that lurk inside?
They appear to be both 1mm and 2mm spade types, male and female (obviously). I have yet to release a pair and measure up, as soon as I get the chance I will.
One option is to try and find a similar connector at a breakers and try to reuse good pins from that, but I know it will be difficult to release them from the original wires without trashing them.
I've trawled the web, and the closest I've found are at www.vehicle-wiring-products.co.uk but these still look too big.
I've also visited a few Auto-Electrical 'specialists' in Leeds, but the best they can come up with is "Hmm, main dealer only, mate." "Hmm, wouldn't get involved in a job like that", and "Hmm, have you tried Maplin?".
Maplin don't appear to do anything like what I need.
So, as the best technical forum on the 'net
, what are your suggestions?
Thanks in advance
or is it a challenge for you to get your teeth into? :mischeif: My VR6
has p!ssed coolant into the 42-pin Engine loom to Non-engine loom connector, resulting in corroded pins.Now I'm more than happy to strip the connector down and clean / replace pins as neccesary, but where can I get hold of nice new versions of the little captive connectors that lurk inside?
, what are your suggestions?Thanks in advance
Thankfully I think it's only the female side that's ropey.
