Well,
Since my car is still running rich
i will try to check the fuel pressure. I will get a double banjo and test it on the fuel rail as Porkiss told me. But iam unsure how i get the full pump to run while the engine is off? Do i short out the pump relay or what?
And a nother question. Can i put 2 air pressure on the FPR via the little hose to check it the pressure is oki?
/Jonas R.
i will try to check the fuel pressure. I will get a double banjo and test it on the fuel rail as Porkiss told me. But iam unsure how i get the full pump to run while the engine is off? Do i short out the pump relay or what?And a nother question. Can i put 2 air pressure on the FPR via the little hose to check it the pressure is oki?
/Jonas R.
