Strange hybrid turbo on ebay.
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Hi,
    Just found this turbo on bay of fleas.
    Not intended to buy or advertise it, but does such hybrid (k26/k29) is sane ? I mean cold side is huge (somebody called K27 truck turbo, and this is k29 ...), and hot side is small.
    Seller says in description http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=7985849008
    that this turbo starts spinning at 2900rpm providing some of boost. Also figures like 2.9 bar overboost sounds like absolute pressure. Or can it be real 2.9 bar ? What fuel ppl should use on such high boost ?
    I'm just wondering, what consequences can be when "marrying" such different turbo sides. Whilst understanding, that it is for driveability - I suspect excessive hot side wear and high backpressure. Am I right ?
    Sau
  • Chris M
    • Sep 2003
    • 1030
    IIRC Doug had a K26/27/29 at one point I think he would have needed a 4" D/P to make it work 100% effectivly. Back pressure would be a issue if the D/P and system wasn't big enough.
    Cheers,
    Chris
    Cheers,
    Chris
    Silver S2 Avant : Sold
    • Audi Parts Guru
      • 1317
      That would be an interesting drive
      S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
      • Doug_RS2
        • 3847
        I had a k29 compressor in a k27 housing - that one looks like a bigger compressor housing.
        Mine would not spool up and although it produced power - very high in the rev range you got no torque.
