Dump Valves
  • CHEN
    • 329
    I have been having a load of problems with my car recently as people might know, I have had a massive boost leak, after doing a test thanks to AndyP test kit (thanks Andy its very good) it appears my forge dump valve is leaking the dmv0006. It makes me think that maybe its not functioning at all my question is can turbo stall cause engine stall? this is another problem I have. Also forge are sending out a free service kit straight away you cant ask for better service than that. I would highly recommend them. I have read a bit on here about whether to inverse the situation of the valve for easier flow, can anyone clarify, was is the original postioning, is changing it making a difference?
    • volcano rs
      • Jun 2005
      • 2265
      when i had mine on the wrong way round the car used to cut out and hold under acceleration since i put them on the right way round i've had no problems i also have forge ones.
