Hello. Im looking to get the Garrett GT35R turbo for my I5 S4. I wanted to ask you guys a few questions. This turbo is available in different hotside on the turbo. Whats your opinion on HP output and spool for each? The car will be daily driven and I plan to make 550+hp:
63 hotside OR GT35r .82 hotside are so reasonably priced that you could buy them both. the .63 is good up to 450hp without too high back pressure in header. For high end power ~550hp+ above 6000 to 8000 rpm you take the bigger one. The .63 gives nice all day drivability at 3000 rpm allready. The more radical cams you have the bigger turbo you need and bigger hot side to avoid too high back pressure. Bigger cams eat and misuse more air but breathing of gases is better inside the cylinder. Better breathing is healthier for high power engine to lower the thermal stresses. Making the right compromises is very difficult.
I would be very interrested in information about what rpm you get full turbo presure, and especially if you have any dyno graphs or numbers that give an impression of the shape of the torque and HP graphs.
Originally posted by palles2
Hi
I have a Garret gt35r with a 0.82 hot side, it is capble af producing 605 hk and 775 nm. on my car, with a 1,0 hot side is can make about 650 hk.
My car is changede from a 2,2 too a 2,6 liters.
In a few months there will come a gt37r, i would wait for that one......
i'm sorri if i write directly to you...i do not speack very english to but i thik it will be possible understand....
I have and audi rs2 that i near to tuned en 2,5 litre by a specific kit of tuned stroker, piston forged, connecting rods...i in front of the decision to by the gt30r or the gt35r....i hase so tuned cam shaft the catcams ... .
My goal is this to have a very power car but with great possibilites to have power at lower rpm so...like thi i buy a exhaust manifold designed for lower rpm (short tube) we have similar motor like this could you tell me for example at 3000rpm wich boost your car have? and like this at 3500 et 4000? it feel goos driving at lower rpm (with gt35r) or is really slow..like the original rs2 turbo.that have the kkk24 no ball bearing???
Is important for me to knwo this ..please answere me...bye
