GT35R turbo questions
  • UrS4
    • Nov 2003
    • 71
    Hello. Im looking to get the Garrett GT35R turbo for my I5 S4. I wanted to ask you guys a few questions. This turbo is available in different hotside on the turbo. Whats your opinion on HP output and spool for each? The car will be daily driven and I plan to make 550+hp:
    GT35r .63 hotside OR GT35r .82 hotside
  • caterpillar
    • 2480
    i will have taken the gt35 with 0.82 hotside....think you have change som other parts too....conrods,cams,injektors,fuelpump and so on.....
    • Tommy200rs
      • 285
      63 hotside OR GT35r .82 hotside are so reasonably priced that you could buy them both. the .63 is good up to 450hp without too high back pressure in header. For high end power ~550hp+ above 6000 to 8000 rpm you take the bigger one. The .63 gives nice all day drivability at 3000 rpm allready. The more radical cams you have the bigger turbo you need and bigger hot side to avoid too high back pressure. Bigger cams eat and misuse more air but breathing of gases is better inside the cylinder. Better breathing is healthier for high power engine to lower the thermal stresses. Making the right compromises is very difficult.
      • palles2
        • 133
        Garret Gt35r
        Hi
        I have a Garret gt35r with a 0.82 hot side, it is capble af producing 605 hk and 775 nm. on my car, with a 1,0 hot side is can make about 650 hk.
        My car is changede from a 2,2 too a 2,6 liters.
        In a few months there will come a gt37r, i would wait for that one......
        402 m 10,99 on street tires.
        659 BHP - 858 nm. 2,6 ccm with 10 x rs2 injectors
        garret gt35r turbo with 1.06 hotside
        2,5 bars of boost :mischeif:
        • BRY
          • 3755
          Details please
          • caterpillar
            • 2480
            palles@ more details.....bore,stroke,cams,injektors........
            • AudiS4
              • 13
              I would be very interrested in information about what rpm you get full turbo presure, and especially if you have any dyno graphs or numbers that give an impression of the shape of the torque and HP graphs.
              Hi
              S4-92
              • palles2
                • 133
                specs
                my specs are:
                in very bad english sorry:
                2,6 liters crank
                lehmann knastaksler
                arrows conrods
                10 rs2 injectors
                3,5 ex. system
                2x m5 fuel pumps
                new ´computer system
                intercooler
                alu water cooler
                90mm inlet manifold
                costum made stempler..
                garret gt35r turbo
                alot more i dont now the english name on.
                it make bost at ca. 3500-3900 rpm.
                410 bhp at 1,0 bars boost 605 hk at 1,9 bars boost
                my car. http://www.bilgalleri.dk/html/gal_visbil.asp?id=24022
                • ferenc
                  • Apr 2005
                  • 53
                  And when have you got the full boost?? 1,9bar on ????rpm?
                  • Audi_CQ
                    • 940
                    • Country: Norway
                    2.6 l crank ? Custom or is it a 2.5(95.5mm) crank with 82.5 bore? Std height 2.2/2.3 or 2.5 tall block?
                    Cheers,
                    Roger
                    • palles2
                      • 133
                      max boost
                      have maxx boost about 4500 rpm
                      the crank is 2,5 ano over bore...
                      • falcoilbasco
                        • 5
                        2.5 litre with gt35r have power at lower rpm???at3000rpm wich pressure?
                        my specs are:
                        2,6 liters crank
                        lehmann knastaksler
                        arrows conrods
                        10 rs2 injectors
                        3,5 ex. system
                        2x m5 fuel pumps
                        intercooler
                        alu water cooler
                        90mm inlet manifold
                        garret gt35r turbo
                        llo,
                        i'm sorri if i write directly to you...i do not speack very english to but i thik it will be possible understand....
                        I have and audi rs2 that i near to tuned en 2,5 litre by a specific kit of tuned stroker, piston forged, connecting rods...i in front of the decision to by the gt30r or the gt35r....i hase so tuned cam shaft the catcams ... .
                        My goal is this to have a very power car but with great possibilites to have power at lower rpm so...like thi i buy a exhaust manifold designed for lower rpm (short tube) we have similar motor like this could you tell me for example at 3000rpm wich boost your car have? and like this at 3500 et 4000? it feel goos driving at lower rpm (with gt35r) or is really slow..like the original rs2 turbo.that have the kkk24 no ball bearing???
                        Is important for me to knwo this ..please answere me...bye
