Are the 7A head and the 3b head the same? without the cams offcourse.
differens on the heads?
7A also has sodium filled valves. The only difference is the water manifold, and the 7A only has 2 studs per exhaust port.Mark Siggelkow
'90 CQ 20vT - NASA GTS-5 (R.I.P.)
'90 CQ-R - NASA GTS-4/5
'00 A4 1.8TQMS (Wife's Daily Driver)
'12 TT-RS (Wife's new DD, on order for May European delivery)
'62 Porsche 356B (another race car)
'03 Kawasaki Z1000 (toy)Comment
So...it appears that the 7A head can be used with just the machining for the water manifold. I have one with all the studs, like the 3B/ABY. I would like to get a nice valve job done prior to removing the head off my 3B, but I'd been concerned about the valves because they have a different part number. They are definately sodium filled, so what's the difference? Is anyone running a complete 7A head with high HP??91 Modded 3B
14 A6 Avant Black EditionComment
Did those heads have the cast manifold? Both of mine had the tubular manifold.Originally posted by martinjsNot all of them, i have a 7a head and the studs are the same as the S2, seen a few like this.
Learn something new every day...
Mark Siggelkow
I was wrong - just checked - the ones with the cast exhaust manifold have all the studs. The ones with the tubular manifold have 2 studs per port. A bit more machining required on the tubular manifold heads then.
Tubular:Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
And Cast:Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
