What's the correct boost level in each gear?
  • Mark Halligan
    • 2001
    Originally posted by martinjs
    Steve, If you have a leak in the small hose from the wgfv to the turbo coldside then you can get high levels of boost as Tom has said. It happened to Mark H also.
    Yes this did happen to me, but only because I stupidly forgot to tighten a clip on the WGFV hose, this has little or nothing in common with the events described above.
    Originally posted by Fat Audi 80
    I am interested if it is possible for a standard car to run dangerous levels of Boost WITHOUT the ECU knowing.
    Well I have always been under the impression that the ECU would know this is happening...........
    As you say probably worth starting another thread to ask the question.
    Mark - Modded
    • Fat Audi 80
      • 10547
      Thanks Mark and Martin, I think I will start my own thread....
      The Perfectionist
      • Mark Halligan
        • 2001
        I have been following this thread and the way it has developed with interest as I have a ported head too.
        I did it myself and spent a lot of time trying to get it 'right'.
        I also removed a fair bit of metal from the exhaust ports, and obvously don't want the same thing to happen to me.
        Bry makes some good points, whilst conceding that the head was probably weakened by a 'tuner' with a chisel (Doug has already pointed out that the workmanship was poor).
        I haven't seen Johnny's engine or the damage. However, it does sound as if something
        'dramatic' happened to cause enough pressure to rupture the port and cause the oil/coolant leak and the subsequant hydrolock.
        So what did it then? From what I have read the motor did run well for a long time. So it would be useful to to find out what did cause it, particularly from a selfish standpoint for me, because as I said above I don't want to do the same. Are there any pics of Johnny's head and the damage, particularly the ports where they split............it would be useful to see how much material was removed from them.
        Lets try to keep it civil and discuss it, there is a difference between argument and debate, and I am sure Jamo doesn't want to see his thread and the issues it has raised go to the same graveyard of deleted threads (where things have got too personal) as others that have gone the same way in the past.
        Mark.
        Mark - Modded
        • Fat Audi 80
          • 10547
          Exactly!
          The Perfectionist
          • BRY
            • 3755
            #35
            No problem with that, pictures after our Thursday night meet.
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              #36
              What a hijack!
              SS
              • Mark Halligan
                • 2001
                Originally posted by 4WheelDrifter
                What a hijack!
                LOL in hindsight yes it was, threads lead off on tangents sometimes, and this one was also getting nasty and a bit too personal for no real reason either.
                You have done the right thing by starting off this new thread.
                Relax Jamo your thread is safe
                Mark - Modded
                  Wow! i haven't seen a storm like this since i told my ex she looked fat in her new jeans
                  • Doug_RS2
                    • 3847
                    #39
                    Originally posted by BRY
                    I was stating facts and haven't gone on about any boost controllers or other ecus.
                    Re: Boost Controllers
                    Would this stop boost spikes blowing the cylinder head to bitz?
                    You forgot the previous chain of events - massive boost leak - someone pressure tested and could not test it properly, someone was told which hoses to visually check - obviously didn't. Someone changed the WGFV to a fuc4ed one (as well as being the wrong one) and didn't tighten the hose onto one of the WGFV connections correctly. Now you have the turbo able to spin up to as much as it can. Add into that the kinked hose to the ECU so the ECU has no idea what is happening - how many human errors, due to incompetance, has caused the car to run badly for a long period of time?
                    You should not just focus on one thing in a small timeframe - a lot more has happened than has been said here. A lot of people have had boost spikes, or ran boost controllers, etc and they have not caused blown exhaust ports.
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #40
                      Sorry Jamo. I tried to save it.
                      SS
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        #41
                        So. What's the correct boost level in each gear again?
                        I'm sure i get more than 0.4 bar in 1st gear.
                        SS
                          Can we draw a line under this NOW
                          If you want to argue about Johnnys car please do so offline or in a boxing ring.
                          I'm interested in other homefry users or MRC chipped cars to compare boost levels as i think this would be nice information available on a mod that is quite common to S2 owners on the forum.
                          • BRY
                            • 3755
                            #43
                            You have a secret in your airbox :mischeif:
                              Must be the magic K&N filter
                              • 4WheelDrifter
                                • Oct 2004
                                • 5773
                                • Country: Devon
                                #45
                                I saw you admiring my big one.
                                SS
