Iam have a running problem which makes the car hesitate @ high RPM under load. Iam suspecting low fuel pressure and am awaiting some unions so i can adapt my oil pressure tester.
Ive also noticed it pinks! just like you've put a marble in each cylinder! Between 6-7K.
What causes pinking apart from being too advanced? It should control that with the knock sensors way before i can hear it shouldn't it? Could this also be caused my low fuel pressure?
When pinking gets bad it is known as detonation and it will wreck an engine, holes in pistons etc. Normaly pinking happens at low rpm high load. Detonation normaly at high rpm, high load.
