Hi guys,
I have one question.
First, I hope I will make myself enough clear, for understanding. Because this kinds of terms in english is a bit hard for me (to translate estonian to english).
Anyway, I getting a pair of 7A cams for my engine (3b, adu em, k26/t04e) and I' m a little bit of confused how to install them. I have read may threads about 7A cams, and suggested here is to use only 7A exhaust cam, not the inlet (loosing a torque and not any different in power).
However, here in Estonia some of guys have some of ideas, and I' m asking what You thinking of it.
Ok, taking exhaust cam and putting it one tooth later. And now comes the hard part, how I transale the word they are using. Anyway, they are thining this. Hall (senser??)will go 13,8* later. And result is: -28 +180 +19 =227
There are some terms, that I could not transale in english at the moment, but I' ll hope You will understand.
Anyway, let' s take the intake cam.
They suggest to remove "gearwheel" form it (cam) and put it back in backwards. So, this will make cam 10* earlyer.
And one of the nuber they are sayng, but I can' t translate:
- +42° (52-10=42)
and
- -2° (8-10=-2)
And finnaly putting the hall senser.
Then turning the cam pulley one tooth back (approx. 14* hall senser) and then again putting hall senser back in normal place.
They are all-so telling that this will make much more torque till 5500rpm and hp.
Now I'm asking from You. What do You think about this? Or is there better way to putting 7A cams in 3B engine?
with best regards,
- +42° (52-10=42)
and
- -2° (8-10=-2)
with best regards,
