boost presure off the WG spring
  • WabTheKing
    • May 2004
    • 2567
    if i disconnect my boost line to my ecu,
    put my std wastegate spring back in with no compression on it
    what will my car boost to?
    if i then wind compression on the spring will this then hold the boost at a higher pressure?
    before anyone rips my head off i KNOW this isnt the normal way people do it on an S2
    and i KNOW there are better ways to do it
    and i KNOW there is then no overboost protection
    i just want to try something
    cheers
    will
  • tekkno435
    • Jul 2005
    • 133
    Ooooh, VooDoo!
    graham.
    Signature censored
    The member formerly known as tekkno300
      The standard car on WG spring pressure should boost about 0.4bar with no overboost if thats what you mean?
      • WabTheKing
        • May 2004
        • 2567
        then with more pre load - more boost?
        • merlin's S4
          • Jan 2005
          • 1539
          In my experience it doesn't make much difference. Maybe a little less lag though! Got a 0.9-1 bar spring if that helps you??
          • MarkPS
            • May 2005
            • 65
            Hi
            You are correct in saying increasing the pre load will increase boost pressure but you may need to change the spring to get to a higher boost
            Running off the spring alone will reduce the turbo spool up speed as the wastegate will start to crack open at about half the rated spring preload pressure without any help from the WGFV and ecu to keep it shut
            Regards
            Mark 88URQ
            88 URQ
