Just cleaned my injectors
  • S2 Ant
    • 3682
    I was wondering that as well!
    Ant
    2011 Kawasaki Z1000
    • Audi Parts Guru
      • 1317
      Originally posted by Doug_RS2
      How do you get less flow in the injectors after they have been cleaned? (100cc down to 97cc /30sec)
      Because deposits build up between the injector tip and injector body, therefore preventing the injector from closing completely, this then allows a small amount of fuel to "leak" from the injector during the closed part of the cycle.
      One of the tests that is carried out during the injector service is a "leak" test.
      • Doug_RS2
        • 3847
        ahhhh - ok - so the car must have been hard to start - if you had 3cc/30sec of leakage in a couple of injectors?
        • Audi Parts Guru
          • 1317
          I've just spoken to the guys at Asnu and they have told me that they are happy to have a few of us visit them on a saturday morning for an injector cleaning session. They said that they can give us a demonstration of what exactly is involved and they will be happy to answer any questions that you might have.
          Please PM me if you are interested in this and I'll arrange it
          • dan_b
            • Sep 2003
            • 3670
            #20
            I'd be interested in theory, reckon after 14 years my injectors might need a good clean - where are they again, sorry...
            • rotoryboy
              • May 2004
              • 3281
              Just under the fuel rail Sorry couldn't resist
              Mark
              Race Clio RS197
              S2 Coupe ABY (Green) - RIP
              S2 Coupe ABY (Blue) - Sold
              • Audi Parts Guru
                • 1317
                #22
                Watford area, Bushey to be precise
                • AAH!
                  • 497
                  • Home: United Kingdom Current: Bhutan
                  #23
                  In the words of Asnu "These additives also coat the internal components of the injector,restricting the fuel flow and pintle travel. The coating also increases the surface tension as the fuel exits the injector, causing a drag effect and by doing so, creating a larger droplet of fuel."
                  In terms of the flow rates I mentioned; the 30sec bit is approximate and was me judging the time it took to fill the tubes. I don't know if the asnu test machine does flow rate tests to an industry standard at a particular rpm rate or whether it is just for its own comparison test.
                  Although rather long winded look here for a full explanantion of all things injector:
                  Angus
                  formally RS2 +
                  • Ski
                    • 2591
                    #24
                    spoke to one of the service centres in my area. they cannot do the work on a saturday and also would not take the injectors out themselves.
                    whats involved in removing the injectors?
                    I'd be interested in doing a group visit on a saturday but watford is a bit far from manchester
                    ABY Coupe
                    • BRY
                      • 3755
                      #25
                      Ski, There's the Lucas Autocentre in Sheffield, I would be interrested in going but not this Saturday.
                      • Audi Parts Guru
                        • 1317
                        #26
                        It's only 3 hours down the M6/M1 etc
                        • PeteRR
                          • 1326
                          Damn!, I'd be well up for that if I was closer
                          I've used Red-Line Si-1 (or something) Injector cleaner...did seem to make a difference, but now worried about the comments about deposits ....time to start using Optimax instead maybe (RR uses 95 octane, 91 with loss of power).
                          Are the Injectors easy to take out?, do you have to de-pressurize the fuel system first, like the older Injection systems?
                          • s2avant95M
                            • 1217
                            • Home: England Current: United States
                            #28
                            id be interested for a visit, as im only about 25 minutes from bushey.
                            Tim
                            1995 S2 Avant, ruby red - ** SOLD TO ROSS **
                            Golf Rallye G60 ** SOLD **
                            Golf MK2 Oaky with R32 engine
                            Audi A6 Avant 1.9 TDi 130
                            Golf MK2 8v Race car
                            • Erikb
                              • Jul 2004
                              • 648
                              Its a 15 minute job to get the injectors out. I also took them to an ultrasoon company to clean them. It was a hell of a difference. It took two hours to clean them and cost where something between 20 - 25 euro a piece.
                              Getting everything sorted out for my 5++ hp project
                                I would be interested, but not till next month and sats are a headache for me unless its WELL early in the morning.
