Conduct a leak down test. That is the only way you will know for sure
which cylinder is acting up. other things to consider are
1) what oilr u using. thin oil would go through your engine
most people tend to use Casrol RS. try an oil change first
2) if it smokes when u lift off sounds like stem seals
3) try starting the car and going for a drive immediately.
does it smoke when u drive or does it smoke when u've stopped.
4) remove mushroom dome from crankcase and wash it out with abit
of petrol so the diaphram moves freely. takes about 10 mins.
5) r u loosing any coolant.
let us know how u got along. above results will determine.
(Ps: worst case worn piston rings, turbo ,stemseals or headgasket)
