Hello.
I have a question that is probably more suited for Doug or Mihnea but I want to share it with everybody.
I have all RS2 mods with a better exhaust and Mihnea chip was giving me almost 2,2 bar peak boost so to prevent any long term turbo damage I asked MRC to send me another map with lower peak boost. They did perfectly.
I also had a stronger spring for the first chip, with the new one Doug told me to reuse the original spring.
So all this to say I changed the chip and opened the wastegate for the less strong wastegate spring.
Car runs smoother at WOT but the turbo behaves as it has an on-off swich, I find it almost impossible to press the gas and hold 1 bar boost for example, something I could do before without any problem. Is either around 0-0,5 bar or the full 1,9 bar boost. Also eveytime I change gear the turbo takes a very long time to spool up. I know this car have lag but this one is not normal and it did not happened with the 2,2 bar chip and the stiffer spring.
So anybody has any idea what might be wrong. At first hand I could think of the wastegate spring or diaphragm.
Thanks in advance.
Rafael
Thanks in advance.
Rafael
