Chaps/Chapeses
Please help me with this. The problem is long running, I have explained it here before and many here have experienced the same issue for different reasons.
The car stutters violently under hard acceleration. Investigations so far have ruled out the following:-
Boost leak - albeit maybe this needs triple checking
Faulty Potentiometer
Potential causes not yet ruled out:-
Knock sensors.
I have recently had the car serviced and the following fault codes have been reported:-
1)00544 - Max change air pressure exceeded - incorrect signal
2)00561 - Mixture adjustment - adaptation limit (mult) not reached
In addition, Paul is about to give me a re-map. I am about to swap over ecu’s and send mine to him for some serious steroid treatment. However, I will be at Castle Combe on Saturday and it may be best to leave my ecu in until then and get the opinions of you more experienced folk…not to mention the fact I don’t know how to swap them.
My questions therefore:
1) Does anyone know the direct causes of these fault codes other than the description provided (ie what does it mean).
2) Can someone take a look at the car on Saturday…possibly…pretty please.
3) Can someone show me how to swap the ecu over.
Thanks boys and girls.
Jamie
Knock sensors.
Jamie
