Hi now i have sussed out the resizing picture thing here is a few pictures of the hose tester i made at work, its basically a plug to go onto the MAF to turbo pipe using a wine cork to block the breather from the cam cover. I have 2 fitments, tyre compressor fitment and a 1/2"bsp fitting to plumb into a garage air line (!!!!!:eek2:WITH A PRESSURE REDUCER IN LINE TO LIMIT THE PRESSURE TO BETWEEN 20 AND 30 PSI:eek2:!!!!!).
Graham
All i got was a small leak through the turbo seals, virtually nothing, but my turbo is worn
Graham
a useful bit of kit to have.
