Hi having probs at the moment with my alternator. could be the belt needs tightening or could be the VR or could be the alternator itself. If it is i need a quick fix so would this fit ? http://cgi.ebay.co.uk/audi-80-90-cou...QQcmdZViewItem
Thanks for your help
3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
where can i get that done? I am going to tighten the belt tomorrow and see if that cures the problem. Then i will change the VR and see if that does it. If not then i will change the alternator thats why i thought i could get that as a cheap quick fix (especially with xmas on its way )
you must have alternator starter motor repairers around your area surely ? its better than buying a second hand one and having the same problem soon after .
they normally check first what needs doing ( the check is normally free )then they repair whatever is needed they normally give you 1 year gurantee so a bit of piece of mind . voltage regulator is normally a cheaper fix than a fully recon alternator. my man in brum normally charges me around £40 but some alternators are more expensive than others.
Nooooooooo, just get your unit refurbished. That unit is not for your car !!!
