Wastegate spring - standard or uprated?
  • OOOO
    • Apr 2005
    • 85
    • Home: Scotland
    Hi all
    My car is going for a remap soon and i need to know if i should be thinking of changing the wastegate spring
    The engine is a newly upgraded RS2 spec ABY;
    (rs2 turbo/manifold/intercooler/injectors/ with big exhaust, bosch fuel pump and 7a exhaust cam)
    Im unsure - can it be remapped for maximum boost with the standard spring or is it better that it be a harder one?
    Every engine reacts differently when being tuned, sure...
    but then at least this should have a pattern - more boost or less boost.
    Apperently it can vary
    I have done a search but can not determine which is good for max performance.
    Its worth pointing out that after asking a few people i have had different opinions so is it just a difference of preference?
    And if it is just a preference thing then what is that preference based on?
    '95..80...ABY
    '99...A4..110..SE
    '99..Bora..110..SPORT
    When Mihnea re-mapped my car he supplied a 1 Bar spring for it.
