Well,
As topic says, what happens if the small coolant pump brakes?
Because when i drive the coolant container drops from max to some place below min. Sometimes i get the warning signal for low coolant level, however when i turn off the car, the coolant slowly returns to the container.
Can this in anyway be due to a broken "small coolant pump"?
/Jonas R.
/Jonas R.
Have you filled the system and removed the bleed nipple from the heater hoses and the one on the top of the radiator?
