ECU swopping
  • Audi500HP
    • Apr 2004
    • 85
    • Country: Chile
    Whats up if we change ours injectors, our map sensor to 3.0 bar version, and we change the MAF in ABY engines..... and then change the ECU software to the RS2 original one? it will start the engine?
    I ask, cause I have two versions stored in my PC of the RS2 chips, waiting to do a Homefrie...........
    Exactly......... what I need to start my engine with my own ABY ECU and the RS2 software?, maybe its impossible with the same encoding, maybe decoding the info and then transforming to ABYs version?
    Audi S2 94 6 speed ABY-ADU 330hp, Lancia delta EVO2 mint
    Dr.Ferdinand
    • kwlw
      • Sep 2004
      • 1025
      • Country: Lithuania
      No. It will not start. You need to change one of resistors in ecu. You can find how to do it in 20v kruemer page/newsgroup. When resistor is changed it works. If I remember correctly nervaz was running such ecu in his "magnum" .
      Sau
      • Audi500HP
        • Apr 2004
        • 85
        • Country: Chile
        I have been looking for the page that you mentioned "20 valve kruemer", but i dindnt find it!!! if you can place the link please? thanks
        Cheeers
        Dr.Ferdinand
        • markrs2
          • 185
          Cheeers
          Its on yahoo groups and you will need to join:
