Howdy from Amerik'er folks! I am pleased to announce, at long last, that the ABZ-powered B4 quattro has been unleashed upon the unwashed masses of the Great Northwest.
There is still some tuning to be done as well as completing the exhaust, but at least it left the barn under it's own (*ahem*... sufficient) power.
The noise is earth-shattering and quite enough to warm the hackles of the dankest Scottish Lighthouse keeper. My neighbors are not quite so enamoured and demanded en masse that I proceed straightaway to an exhaust shop, but I've bigger and better plans... namely to ignore them.
At any rate, here is the list of modifications so far:
Custom engine block brackets - to retain the unibody cradle mounts
Aluminum PT 3.6 flywheel and machined pilot bearing adaptor to retain 01A transmission.
AFCO aluminum radiator
Carbon fiber hood
RS2 headlights (duh)
Polyurethane control arm bushings
Ceramic sprung clutch disc and uprated 200tq pressure plate
Stainless brake lines
Battery in boot
A/C erradicated
Fiberglass RS2 bumper (saved 40lb over US junk)
VEMS engine management computer
Planned mods include installing my Brembo 996 calipers, 28.6mm front and 20mm rear sway bars, fabricating a carbon fiber intake manifold and timing covers (saves 50lb), constructing coil-overs and some sort of 4-point harness with matching seats.
More to the point: Yes, it fits.
Ben
Carbon fiber hood
Battery in boot
A/C erradicated
Ben
Keep us posted, dude !!! And pics would great if you have any...
Is the mounts you fabbed for the engine mounts on motorgeek?
