Stuck at 400bhp any ideas ?
  • aby1
    • Nov 2005
    • 17
    I have an ABY, pauter rods, fordged pistons(8.5-1), rs2 exhaust cam, running K27, tubular manifold, 3in exhaust(1free flow silencer) larger intercooler. Recent rolling road and mapping session got 400bhp @ 1.6bar 6500rpm and 380lbs of torque, increasing the boost past 1.6bar did not improve power just the torque(as you would expect). I was looking to run up to 2 bar (if necessary) and achieve 450+bhp. Anybody got any ideas ?
  • Dave cook
    • 312
    GT40 :mischeif:
    • dan_b
      • Sep 2003
      • 3670
      Buy an RS6?
      • aby1
        • Nov 2005
        • 17
        There aren't many RS6s under 1200kgs !!
        Was looking for more useful a ideas, surely more boost = more power ?
        • Baldy
          • 469
          • Home: Sikkim Current: British Antarctic Territory
          just search the forum and look for all the ppl who are going for 500+bhp and see what ur missing
          Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
          0-60 4.9
          1/4mile 13.5
          • dan_b
            • Sep 2003
            • 3670
            Sorry, being cheeky!
            Who has done the ECU map on your car? What injectors are you using? Fuel pump? You probably need a bigger turbo regardless...
            • aby1
              • Nov 2005
              • 17
              Motec, twin fuel pumps, 750cc injectors, charge temp remaining low while increasing boost. K27 has got to be more than 400hp !
              • Billman
                • 4129
                You must have more boost past the 5000 RPM! How is your boost curve now?1.6 is the overboost or the boost at 7000 RPM ? Can your turbo flow that much air?
                Go Holset or Go RS4
                • Audi_CQ
                  • 940
                  • Country: Norway
                  If more boost(with same charge temp, A/F and no knock/ign. miss.) doesn't give power, ported head and better cams is a good start.
                  • AnLe
                    • Dec 2003
                    • 291
                    what size is your turbo (I mean the real size, diamater of inlet and outlet)
                    • aby1
                      • Nov 2005
                      • 17
                      my cylinder head is mildly ported 3 angle valve seats etc, how important is that area in a turbo engine ? I'm looking for at least another 50bhp
                      Cams on the other hand, i'm running an rs2 exhaust cam and standard rs2/aby inlet cam, is this the right chioce will that restrict it to 400bhp ? The engine pulls very hard to the redline 7500 and full boost is @ 3700. Max power 6530.
                      Not sure about the turbo trying to get full spec from vendor. Even the if it was the smallest spec K27 I would have thought it would give more than 400bhp ?
                      • AnLe
                        • Dec 2003
                        • 291
                        The "K27" does not mean anything it can be still 250hp turbo, you really need to know your turbo.
                        • Dave cook
                          • 312
                          have you a pic of the turbo?
                          • AnLe
                            • Dec 2003
                            • 291
                            how much is back pressure?
                            • robo
                              • Aug 2004
                              • 2086
                              Hello &
                              Are you running mtm chips by any chance?
                              sigpic_________
                              Rob
