sounds like antilag at WOT
  • WabTheKing
    • May 2004
    • 2567
    car has developed a problem
    drives fine normally
    sink your foot into the carpet at at bout 4000rpm coughs and back fires and sounds like anti lag, sound good but not ideal.
    suspect fuel pump?
    cheers
    will
  • aby1
    • Nov 2005
    • 17
    Air flow meter ?
    • dkw_dude
      • 555
      • Country: Norway
      suspect fuel pump?
      cheers
      will
      I have the same problem, exact same symptoms at WOT. It happened after I cleaned my injectors a while ago (at BOSCH dealer) and I havent been able to cure it.
      Pressure tested ok, swapped MAF with another one which is supposed to be good, still the same. When lifting off the throttle a bit it pulls cleanly again.
      Would be nice to get any input on this!!
      Cheers Leif-Helge
      Leif-Helge
      -91 S2 VEMS and Comp Turbo
      -12 B** 530XD Touring "S2 parts transporter, and daily driver"
      • quattronutter
        • Jan 2005
        • 690
        dont overlook things like ht leads and coilpacks,worth changing your plugs too if they are not fresh ones...
        • WabTheKing
          • May 2004
          • 2567
          car has stopped starting now, gonna change my fuel pump
          • AAH!
            • 497
            • Home: United Kingdom Current: Bhutan
            The fault you describe sounds very similar to one I had. I pulled the blink codes which pointed me towards a knock sensor. The ECU in a ABY/ADU can retard the boost if the knock sensor detects knocking or if the knock sensor is faulty. My problem was a poorly soldered terminal in the knock sensor connector. Repairing the connector sorted it.
            If you go down the coilpack replacement route, as well as the above check the power output stages (POS) aka power amplifiers. These are the things that the coilpack leads plug into. In my case I had a non-firing cylinder that was not fixed by replaceing the coilpacks which ended up being a failed POS channel. This was fixed by rewiring the connectors and using the spare channel on the POS.
            Also cleaning injectors can slightly reduce fuel flow.
            HTH
            Angus
            formally RS2 +
            • WabTheKing
              • May 2004
              • 2567
              mine is a 3b
              • AAH!
                • 497
                Oh. In that case probably best to ignore, although IIRC the knock sensor on the 3B retards the ignition, I don't know but may be worth checking.
                formally RS2 +
                • dkw_dude
                  • 555
                  • Country: Norway
                  I recently changed both my knock sensors, one of them was looking really bad, see pic. But I didn't know that it could cause this kind of behaviour?
                  I had a look at the connectors, some of the insulation on one of the wires was missing, and the plastic inside the connector which separates the pins was broken. No visible short circuit though.
                  I have a 3B, could these symptoms be connected to the ignition amplifyer/coil? Or will it be more of a full stop situation as this single unit feeds sparks to all cylinders?
                  Reduced fuel flow, hmm maybe I should test with a set of "uncleaned" set of injectors and see if it's back to normal..
                  Leif-Helge
                  Leif-Helge
                  • WabTheKing
                    • May 2004
                    • 2567
                    car starting again now after fuel pump relay change
                    BRY clear 4 fault codes yesterday
                    gonna see what it does later
                      Was the old relay preventing sufficient voltage from getting to the fuel pump - did you take any measurements before and after ?
                      • WabTheKing
                        • May 2004
                        • 2567
                        car cured now after reley change
                        • dkw_dude
                          • 555
                          • Country: Norway
                          My car is ~ok again..
                          Measured fuel pressure under load, fuel pressure rose(?) parallell with manifold pressure ->ok
                          Installed new dizzy! (old one leaked oil internally)
                          Smoother running and stronger from lov revs, a lot of hesitation gone () but still cutoff.
                          Changed MAF, symtoms did not change.
                          Changed plugs from Bosch FR5DP (I know, not original but bought from a well known Norwegian tuner. Don't know replacement interval on them) to the old original Bosch plugs. And no cutoff since.
                          But still holding back a little @ high boost, I'm beginning to think that it is running lean and then the knock sensors retards the ignition. Maybe get me a WB lambda kit and check..
                          Cheers Leif-Helge
                          Leif-Helge
                          • WabTheKing
                            • May 2004
                            • 2567
                            my hesitation has reared its head again, changed fuel pump - no differance
                            not a consistant problem as it sometimes goes away?
                            • topsparky
                              • Oct 2005
                              • 2014
                              could it be because you've still got ya wellys on from sheep shaggng in glossop
                              1. SHORT SHIFT KIT
                              2. PORSCHE CAYENNE CALIPERS
                              3. H & R SPRINGS
                              4. BILSTEIN SHOXS
                              5. NEW BUSHES AND HP2 STRUTS
                              6. UPRATED HIGH OUTPUT COIL PACK
                              7. ,3" turbo back s/s/ exhaust
                              8. fmic fitted
