Help Help Help
  • s2avant
    • 2426
    #31
    Charlie,
    Heres the info on testing the Hall Sender: Checking Hall Sender
    Ben
    • charlie
      • 447
      #32
      Originally posted by s2avant
      Charlie,
      Ben
      Thanks ben. It confirms my previous finding regarding voltage supply.
      RS2 MTM
      • charlie
        • 447
        #33
        Ohh F$$k
        JUST WAS CHECKING THE TIMING AND I'VE NOTICED THE LINE MARK ON THE
        FLYWHEEL DOES NOT LINE UP WITH CRANK PULLEY MARK
        FLYWHEEL MARK IS SLIGHTLY AHEAD OF CRANK PULLEY MARK
        ON THE RS2 THE CAMSHAFT MARK IS A "V" ON THE ROCKER COVER
        CAN SOMEONE PLEASE TELL ME HOW THIS SHOULD BE TIMED AS
        I CAN'T THINK STRAIGHT NOW ( RED MIST HAS RETURNED)
        RS2 MTM
