could someone tell me how to fix this leak and is it safe to just open this "bolt"? Is there somekind of O-ring seal?
Power Steering oil leak
This is a common problem on the S2. All you have to do is undo the top banjo, then undo the crosshead cap. You can buy the kit from the dealer for a few pounds which has a new cross head cap and 'O' ring. Easy jobMark
Race Clio RS197
S2 Coupe ABY (Green) - RIP
S2 Coupe ABY (Blue) - Sold -
As Mark says "easy job"Originally posted by rotoryboyThis is a common problem on the S2. All you have to do is undo the top banjo, then undo the crosshead cap. You can buy the kit from the dealer for a few pounds which has a new cross head cap and 'O' ring. Easy job
You'll be wanting part number "026 145 541" from either vagparts or a dealers. Cost about £2.50 including the vat.
Old one will need a bit of brute force to free it off. Hammer and chisel works a treat unless you have the right tool.
Click the pic for a bigger image.
Jas
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)Comment
ANyone know where I can get another one of these from, my o-rings just perished and fluid ******in out?
Last time i got one for the S2,enquired at dealers, bloke told me I had to buy a complete power steering pump
,ended up getting one from VAG parts. Since they are no more..any ideas?? Have tried very similar o-rings I had lieing around but still not perfect..
cheersComment
might be wrong here but pretty sure you should turn the car off and pump the brake pedal to ensure the bomb is depressurised as the fluid in those liines is at very high pressure normally...sigpic
1992 3b S2 CoupeComment
