Please could anyone tell me the diameters of the pipe you cut to fit a boost gauge as the VDO fitting kit does not include a T piece and the pipe supplied is only about 3.5mm external diameter so I will have to increase, maybe?
3mm id works best for the small joins but can be difficult to secure with clips - I use superglue - seems to work fine and does not distort the hose like small clips can...
Try 'German, Swedish & French' at the end of Shepcote Lane, I bought some from there recently. I can't remember how much it was, but it's not expensive.
Andy
