Wastegate Regulation
  • wastegates
    • Dec 2004
    • 351
    • Country: Spain
    Hello friends......
    Somebody knows the exact measurement of regulation of wastegate.
    It is that I complete mecanic that attempt to put chip to the car exempt him the seal and I screw it and now which I do the ECU with Paul I want to regulate it in its origin .
    Aid
    Charles
    Audi S2 Coupe ABY 1994
    Barcelona
  • BosnianS2
    • Apr 2005
    • 322
    • Home: Bosnia and Herzegovina Current: Germany
    I think that what you are looking for is the original position of adjustment screw on top of the wastegate as it comes from factory. I dont think that exact position matters that much, because difference is minimal when you tighten the screw, and especialy if you added chip to the car now, than extra couple pounds of boost will not matter, which is what you get when you tighten the screw all way down. This is what my understandig and experience has been.
    I would loosen the screw half way up and leave it there.
    I may be wrong, someone correct me please if my statement is not right.
    i hope this helps
    • wastegates
      • Dec 2004
      • 351
      • Country: Spain
      Thanks BosnianS2
      This is what they did.
      Although now already this of origin, except the Wastegate that this almost equal I now create.
      Charles
      Barcelona
        OMG, bleed valve alert!!!!
        Want to remove that nasty setup mate.
          Firstly - get rid of the bleed valve !
          Secondly - the factory setting for the standard wastegate spring is 25mm from the upper perch to the inside surface of the wastegate cap.
          Paul
          • wastegates
            • Dec 2004
            • 351
            • Country: Spain
            Paul
            I do not finish understanding it Paul....
            It can draw to see it?
            Charles
            Barcelona
            • GandalfS6
              • 332
              • Country: South Africa
              Setting the WG
              Another way to set the WG is to unplug the N75 (WGFV) and to see how much the car boosts then. A standard WG should only boost 0.4 bar.
              1995 Silver S2 (ADU) Coupe
              2006 Porsche 997 Carrera S
              2006 Misano Red RS4
              2004 VW Touareg V8
              2007 Golf Mk1 Race Car
              2004 Mercedes Benz Vito 112CD
              • wastegates
                • Dec 2004
                • 351
                • Country: Spain
                Thanks GandalfS6
                Charles
                Barcelona
                  I always forget that - it easy to test the way Gandalf describes !
                  Paul
