When your engine is balanced complete, parts should be balanced independently ie. so you can replace the flywheel, and just have the new fly/clutch assembly balanced. I suspect it depends on your balancer.
A couple of grams out may not be much, but at 7,000+ rpm will be an issue! The manufacturer should be able to tell you what tolerance the flywheel is balanced to from the factory, personally for the relatively small cost I'd get it looked at.
) it helps speed up your gear changes a bit.
