Originally posted by ~Delta
Valve Stem Oil Seals
Fair enough the dealers aren't to be trusted and I completely agree with the comments about doing a job properly, but I was only stating that the Audi workshop manual lists a method for doing this job with the head in place! The original question from Mark (rotorboy) was whether or not it is possible, so if this method is in the Audi manual then it must be regarded as a genuine way of doing the job! I'm not suggesting that one way is better than the other or that the head removal method doesn't have it's merits, but in this case the head has already been off and as Mark says, the relevent items have been checked. So to me the benefits of being able to do it this way are very obvious!!'93 S4 Avant now back on the road complete with new shiny go faster bits.
True, Mark has had his cylinder head off, but are the valve guides serviceable? The point is if the valve stem seals are shot, the guides could be worn as well!
To check the valve guides, the collets would have been removed and probably the valves themselves! Was this done? It's hard to check tolerances without stripping the head down completely to a bare carcass.Never show a fool a half built house.
Never underestimate the power of stupid people in large groups.
Life is like a **** sandwich
The more bread you have, the less **** you eat
Originally posted by rotoryboyeverything was fine then i put the head in the hot wash, which hardened the seals
Originally posted by ~DeltaAh, but we all know what the Stealers can be like...Mark - Modded
