1.8T Coilpack installation
  • merlin's S4
    • Jan 2005
    • 1539
    I've just found a really good guide to installing the coilpacks from a 1.8T engine into an ABY or AAN on the s-cars website. I know this has been talked about on here before and has obvious advantages, £25 per coilpack being the main one and the fact that these coilpacks each have an integral POS, but are there any major disadvantages?? In the guide that I've seen, the new coilpacks are just clipped onto the sparkplugs and aren't bolted to the head like in other conversions I've seen. Is this ok? It certainly looks like a nice easy way of doing it! My other concern is that without the coilpack cover (won't fit over these coilpacks), won't there be trouble with dirt finding it's way down the sparkplug holes and possibly into the cylinders when the sparkplugs are removed for any reason? What do you reckon, is it worth the hassle or no???
  • Jas11n
    • 5067
    Damn it, just spent 30 mins hunting and I can't find the link I read the other day on an American forum that was talking about that run-through,
    and it was mentioned that the cover would go back on if you were to use proper heat resistant wiring, so getting rid of all that heat protective shielding. Using these type of coilpacks meant that the fixing posts for the cover can remain in place.
    I can't see any reason why the coil packs would come out whilst only being held in place by clipping onto the plugs. Famous last words though
    My only concern (very small concern) would be the issue that Audi had with the recall of cars with those type of coilpacks, although I understand that's all sorted.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • Jon441cc
      • Dec 2005
      • 2061
      http://www.s2forum.com/forum/showthr...ight=coilpacks
      • Jas11n
        • 5067
        Thats a run-through on replacement of the standard ABY/ADU/AAN coilpacks Jon, Merlin is taking about retro-fitting the later S3 type coilpacks with built in power output stages.
        • Jon441cc
          • Dec 2005
          • 2061
          http://forums.audiworld.com/s4s6/msgs/85072.phtml
          Is this what you were looking for ?
          • Jas11n
            • 5067
            Linky to the conversion.
            And also here,
            If and when my coilpacks fail, I'll defo be looking at this route as the OEM ones are IMO stupidly priced.
            • Jon441cc
              • Dec 2005
              • 2061
              Jas, how much are the OE ABY/AAN coilpacks?
              do you get the wiring with them ?
              • Jas11n
                • 5067
                IIRC, GSF sell then for around £50/60 each. I think those come with the wiring which you then splice into near the POS's.
                Those in that thread you posted above by Marty are direct from Beru and don't come with wiring. I think
                Sorry to Merlin for going off topic
                In answer to Merlins question at the end of his post, Yes I think it's worthwhile, especially as we now have a complete guide on how it's done.
                I just hope I don't have to do it for a while yet
                • Erikb
                  • Jul 2004
                  • 648
                  I made one for my 3b engine a few weeks ago. Here is a list with the prices, dont buy your parts according to this list because there are some parts which fail:
                  I just ordered the parts for the 3b to 1.8t coilpack conversion :
                  5 pieces 06B 905 115L ‚ 27.80 P/p
                  5 pieces 4B0 973 724 ‚ 4.48 P/p
                  10 pieces 000 979 133 A ‚ 1.34 P/p
                  25 pieces 357 972 741 A ‚ 0.48 P/p
                  5 pieces 6X0 971 921 A ‚ 1.19 P/p
                  3 pieces 000 979 134 ‚ 1.34 P/p
                  2 pieces PN 191 972 704 (backlight connector)
                  prices in euro excl. VAT
                  Erik
                  Getting everything sorted out for my 5++ hp project
                    It is also in the guides and top tips section of the site 1.8T coil pack install
                    • Doug_RS2
                      • 3847
                      We fitted a conversion kit to a customers car - the cover goes on no problem. Runs fine on a remapped car. I'll be doing this on my car and run it at 2.5bar.
                      • Jon441cc
                        • Dec 2005
                        • 2061
                        Guess what i fitted today :mischeif:
                        • audiman
                          • 4827
                          Any way of doing this to the 3B????? Now that info would be even more useful.
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            LMAO I was just thinking that.
                            SS
                            • Billman
                              • 4129
                              Check also this out! For doing a 3b work without the distibutor!
                              I think for this you need also a AAN, ABY ECU!
                              The green letters on the menu! Problem or you maybe the language!
                              Go Holset or Go RS4
