Weeping Housing, help!!
  • Graham
    • 1622
    Hi Guys, i have a tiny weep of coolant from the housing bolted onto the back of the block what the Heater matrix hose goes onto. (The worst one to do on the pipes change). What is in this housing?, is it just a bolt on adapter to hold the pipe to the block? or does it house something?. Is it an O-ring, or a paper gasket?. Im sorry its questions, questions, questions, but its annoying re-bleeding every 4 days and with all the gubbins above removed wont be too bad to do hopefully, i just dont want to go in blind.
    Any help much appreciated
    Graham T
  • mcandmar
    • Apr 2004
    • 5118
    Graham its just an adapter to mount the hose, nothing in there at all. On my 7A its a metal pipe, and on the ABY its a plastic part, fairly sure it just uses a rubber o-ring to seal it and one small bolt to hold it in place.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • SteveH
      • 4460
      yup, it's an O ring in there and one M6 bolt holding it in place. Not an easy part to get at!!
      91 Modded 3B
      14 A6 Avant Black Edition
      • Graham
        • 1622
        Cool, i might just take it off and make a new one at work from St/St, or if it just needs an o-ring fit a new one.
        Cheers, i owe you a Pale ale (Coopers)
        Graham
        • pixsaudisex2
          • Sep 2004
          • 3110
          see usefull stuff on here ..
          just under me car and well drip drip .. and whats that plastic wet looking thing down there ,,,and before i go and brake the plastic il see what the old forum says so thanks to all invloved in this thread before ,,,
          because i can now go and tackle this with a bit more knowledge and well they do say knowledge is power,,,,
          Sadly it is sunny out there
