Hi Guys, i have a tiny weep of coolant from the housing bolted onto the back of the block what the Heater matrix hose goes onto. (The worst one to do on the pipes change). What is in this housing?, is it just a bolt on adapter to hold the pipe to the block? or does it house something?. Is it an O-ring, or a paper gasket?. Im sorry its questions, questions, questions, but its annoying re-bleeding every 4 days and with all the gubbins above removed wont be too bad to do hopefully, i just dont want to go in blind.
Any help much appreciated
Graham T
Graham T
